Can't log QSO"s in the 222 MHz band
k4xr
Post by k4xr »
I apologize if there is an earlier message on this topic, but I couldn't find it. I am using the latest version (1.39) and I am unable to log contacts on the 222 MHz band. I get an "OUT OF BAND" message when I enter a frequency on the 222 MHz band. I have made sure that my IARU and my ITU settings are correct. Any help will be greatly appreciated!
73, Craig Compton K4XR
Re: Can't log QSO"s in the 222 MHz band
That is because that band is not in the region 2 bandplan
Let me have your allowed bandplan for 222 and I will amend the bandplan
k4xr
Post by k4xr »
Here is the IARU Region 2 bandplan. However, the US bandplan is different. Not sure which you want. The US allocation does not include 220.000 through 222.000 anymore, but in quite a few region 2 countries, 220-222 is still allocated for amateur. Also, the US now has an amateur allocation at 219-220 for "Fixed Digital", but I don't think anyone will be wanting to log contacts for that range. Would guess that the best solution may be just 220-225 since that should take care of most of the countries involved.
73, Craig K4XR
1.25 METER IARU Region 2 Bandplan
Frequencies (MHz) BW (Hz) Mode Applications and observations
220.000-222.000 12000 All modes ACDS
222.000-222.050 500 CW, DM EME and Weak Signal
222.050-222.060 500 CW Beacons
222.060-222.070 500 CW, DM Beacons, ACDS (Digital Beacons)
222.070-222.100 500 CW, SSB, DM Weak Signal, SSB/CW Calling QRG 222.100 MHz
222.100-222.150 2700 CW, SSB Weak Signal
222.150-222.250 Local Option
222.250-223.380 12000 FM, DV Repeater inputs (exclusive) (output +1600 kHz)
223.380-223.520 12000 FM, DV
223.520-223.640 12000 All modes ACDS
223.640-223.700 12000 All modes ACDS, Links and control auxiliary to repeaters
223.700-223.750 12000 FM, DV ACDS, IVG (10 kHz channels)
223.750-223.850 12000 FM, DV Local Option
223.850-225.000 12000 FM, DV Repeater outputs (20 kHz channels) (input -1600 kHz)
CraigC wrote: 27 Aug 2019, 13:11The US allocation does not include 220.000 through 222.000 anymore
This is why its not in the region 2 bandplan
Regional variances are covered in the bandplan_DXCC???.xml files, however we will not add frequencies that are not regionally or Internationally allowed.
The user can add whatever frequencies he wishes, just modify the bandplan_r2.xml then save it with the name bandplan_r2_user.xml so that it will not be overwritten during a program update and will be selected automatically by Log4OM on start up.
The bandplan files are located at C:\.......................\AppData\Roaming\LogOM
k4xr
Post by k4xr »
Terry,
I DID NOT ask that you "add frequencies that are not regionally or Internationally allowed." 220-225 IS Regionally Allowed, but your suggested solution does not work, and I've screwed around long enough trying to fix it. I've used LOG4OM for several years, but am moving on. Good luck to whoever developed some brilliant rationale for not including the 220 band that is allocated to and used by dozens of countries.
CraigC wrote: 28 Aug 2019, 21:01 Terry,
Sorry your upset but you said "The US allocation does not include 220.000 through 222.000 anymore" which prompted my reply.
I don't know why we did not add the band, I will check this out, and its a shame that you feel you wasted your time but as as I said it can be overcome quiet simply.
Any way we are sad to see you leave and hope that you find a program more suited to your requirements.
