jtdx
LU4FTA
jtdx
Post by LU4FTA »
Ciao, il mio problema è che essere collegato al software JTDX e sto lavorando in modalità FT4 mi fa risparmiare i QSO in modalità MFSK16. Apprezzo l'aiuto
73 di Felipe LU4FTA.
Re: jtdx
Hi, with JTDX you should use JT-Alert to be integrated with Log4OM through the UDP protocol, following the chain: JTDX -> JT-ALERT and then JT-Alert to Log4OM
If you don't want to use JT-ALERT you should configure Log4OM (Communicator) to monitor the ADIF file generated by JTDX (you can find it in the FILE menu, with a specific menu item that point out to that file).
In communicator, simply set the application to monitor the ADIF file of your choice. Communicator can be started automatically setting that option from settings menu (last tab)
