Log4om and winkeyer, with cw speed pot enabled.
If you send prosign CT ( _._._ ) from a key
log4om will change the winkey speed from what every it's set to,
to 9wpm.
Sending any CW prosign should not effect either Log4om or Winkey
I think there is an error in Log4OM
Log4om and winkeyer Prosign problem
Re: Log4om and winkeyer Prosign problem
This has been added to our list
Please do not double post, I have deleted the duplicate posting
Just checked out V2 and the problem still exists.
Doesn't appear to be a way to disable the speed pot in this version so no work around that I
can see
Dave G8PGO
can see
Dave G8PGO
Any idea when this may get fixed
Using K1EL USB winkeyer rev. 31 i'm totally unable to reproduce the issue.
The speed pot message is sent only when i move the pot on the WK.
I've tried all combinations of parameters but i can't reproduce that issue. Can you kindly tell me what WK version are you using?
