Hello!
I've been enjoying using Log4om at home as my main station logbook. I want to also use for my 2e0txe/p logbook. Am I correct in assuming that this just needs to be done by creating a new profile on Settings -> Options. And then just selecting either 2E0TXE or 2E0TXE/P depending on which I want to use?
or is there an easier way?
Many Thanks
Damian - 2E0TXE
Main Log and Portable Log
Re: Main Log and Portable Log
Damian
You dont really need to do that unless you want to completely separate your /P QSO's for some reason?
All I do before going /P is to change the 'Station call' in the config/station info tab then every QSO logged is logged as using that station call, G4POP/P, and at any time I can sort and select on the /P for exporting, QSL handling or whatever
