Ic 7610 and cat support
n4xd
Post by n4xd »
I've searched the forum and haven't yet found a solution. I'm trying to get log4om to communicate with the 7610 for general logging. Not WSJT just ssb or cw. I did try the set up from one of the posts that had it working with wsjt but that did not work for me.
I also had a K3 working with log4om.
Have tried switching comm ports, have tried some of the other solutions but nothing is working.
I have DX Labs Commander working with the 7610 and did have an IC 7300 working with Log4OM. But no joy with the 7610.
Using USB cable and am certain I've the right comm port (not running Commander at same time of course but using that comm port).
If someone has this combination working might you please send me the 7610 set up you are using?
Ron
N4XD
Re: Ic 7610 and cat support
Ron,
Check your OmniRig (cat) setup and connection. If I recall I think I've read here that there were tweaks needed in the OmniRig ini file for that rig or a different ini file ended up being used.
