Log4OM V2 - JTDX - Omnirig
Posted: 15 Jan 2020, 19:32
by sq9jxb
Welcome.
I installed Log4OM V2 and encountered a CAT error.
in Log4OM set CAT as Omnirig, in JTDX the same and the effect is such that in Log4OM CAT works properly and in JTDX there is no connection with Omnirig.
Omnirig version 1.19.
Regards
Re: Log4OM V2 - JTDX - Omnirig
Posted: 15 Jan 2020, 20:05
User guide
It is not necessary to run Version 2 as an administrator unless Omnirig or other associated programs (e.g. WSJT, JTALERT) are elevated for multithreading in which case Omnirig and all programs working with it should also be elevated (Run as an administrator).
So you need to install Log4om, Omnirig and JTDX to "Run as an administrator"
Posted: 16 Jan 2020, 12:21
As an alternative, you can start Omnirig first, with admin privileges. That way it will share his communication ports to multiple applications.
Posted: 16 Jan 2020, 15:08
by sq9jxb
Hello Danielle
Everything works as it should.
Posted: 16 Jan 2020, 20:22
Great,
dovizenia dziekuje bardzo, i like a lot vodka from your area when i work in Warszawa:)
