v2 - Omnirig - FT-950
2e0txe
Post by 2e0txe »
Setup the new version, using Omnirig and my FT-950. Log4OM insists the radio is in split mode can't click it out of split in Log4OM screen, or toggling split on the radio makes no difference either.
Log4OM v1.whatever I have installed works perfectly.
2e0txe
Re: v2 - Omnirig - FT-950
Post by 2e0txe »
Found this in the log4om v2 logs:
Code: Select all
2020-01-16 02:45:49.5898 ERROR:       [OmnirigEngine][#=zBafgiGfkEFroDXeuWge5yZU=] : Error in mySink_CatInformationUpdatedEvent
[EXCEPTION] Object reference not set to an instance of an object. System.NullReferenceException: Object reference not set to an instance of an object.
   at L4ONG.BL.CAT.OmnirigEngine.#=zBafgiGfkEFroDXeuWge5yZU=(Int32 #=z1JSpaQFBlRAQ, Int32 #=zRdvkwWM=)
2020-01-16 02:45:49.5938 ERROR:       [OmnirigEngine][#=z4nzBAWqJ8a4beNjvhA==] : [EXCEPTION] Object reference not set to an instance of an object. System.NullReferenceException: Object reference not set to an instance of an object.
   at L4ONG.BL.CAT.OmnirigEngine.#=z4nzBAWqJ8a4beNjvhA==(Int32 #=z1JSpaQFBlRAQ)
2020-01-16 02:45:49.6018 ERROR:       [OmnirigEngine][#=zBafgiGfkEFroDXeuWge5yZU=] : Error in mySink_CatInformationUpdatedEvent
2020-01-16 02:45:49.6218 ERROR:       [OmnirigEngine][#=zBafgiGfkEFroDXeuWge5yZU=] : Error in mySink_CatInformationUpdatedEvent
2020-01-16 02:45:49.6297 ERROR:       [OmnirigEngine][#=zBafgiGfkEFroDXeuWge5yZU=] : Error in mySink_CatInformationUpdatedEvent
2020-01-16 02:45:49.7456 INFO:        [OmnirigEngine] :      CAT OMNIRIG2 -> LOG4OM RIG1 IS ONLINE
Seems Omnirig cannot be open. Can you send me the full log to iw3hmh (at) log4om.com ?
Please add reference to this thread
2e0txe
Post by 2e0txe »
The frequency display changes from radio to log4om and the other way around when you cycle around the cat display, the radio updates and mode words etc, its just stuck in split mode.
Error log on the way.
wo9b
Post by wo9b »
Same report on a FT-891. Split is being reported. RX is being attributed to VFO B (which makes sense if split is being reported). CAT is functional as regards frequency and mode. Both can be changed.
Also CAT is being reported as active (Green)
2e0txe
Post by 2e0txe »
Tried fresh install of Omnirig (bundled) with Log4OM v2 on a fresh install of Windows 10 whilst I had access to a new machine.
Exactly the same, Log4OM shows the radio in Split mode, VFO changes in both directions, it is just stuck in Split mode and you cannot turn it off in the CAT window, toggling Split on the radio itself makes no difference.
Definitely a problem with v2 as v1.4 works perfectly.
2e0txe
Post by 2e0txe »
This is still not fixed in the latest release. The radio is always reported as in SPLIT mode despite the radio not being. Doesn't make any difference pressing SPLIT on the radio or trying on CAT control window.
Have tried using the bundled Omnirig and also the newer version available to download.
My FT857D works no problem, but the FT950 is always reported as being in SPLIT mode.
