First of all many thanks To Daniele and everyone else for a superb update to Log4OM, especially the propagation info and general style, which is very clean and readable.
I am trying to get spots from Log4OM V2 to Flex. I know I can use SliceMaster, but I would sooner have a minimum of software running. I have tried using UDP outgoing with the local server connected, but not sure how to configure CAT correctly incoming.
Has anyone tried this yet?
73 Andy F5VAI
Log4OM Cluster Spots to Flex 6000
Re: Log4OM Cluster Spots to Flex 6000
Telnet cluster start the server and then connect flex to server
On further research I think I am correct in saying that there is no capability in SmartSDR to directly connect to a cluster server via telnet. Spots can be provided from certain programs such as N1MM, FRStack, Slicemaster, DXLabs, and Logger32 as well as any other third party program that uses the new Flex Spot API commands in the radio.
I was hoping that V2 would have more API connection to Flex, as previously mentioned in a number of forum discussions. Hopefully this is something we can look forward to.
Anyway enjoying the new software in other ways. Thank you.
Andy F5VAI
Andy F5VAI
That would be really great. Being able to feed spots to SmartSDR. Here is the link to the Flex SSDR Spots API https://www.flexradio.com/downloads/?wp ... x-6000-api
From the SmartSDR Manual:
http://wiki.flexradio.com/index.php?tit ... TCP/IP_API
http://wiki.flexradio.com/index.php?tit ... 1568633096
You could also ingest spots by simply sending a TCP/IP packet to the Flex radio as described here:SmartSDR for Windows introduced a feature that allows Spots, supplied by third party programs, to be displayed directly in the Panadapter window. Some of these programs include N1MM, FRStack, Slicemaster, DXLabs, and Logger32. While there is no capability in SmartSDR to directly connect to a cluster server via telnet, spots can be provided using these programs as well as any other third-party program that uses the Spot API commands in the radio. This section explains the various Spot controls that are available in SmartSDR."
Flex 6600 - Spiderbeam
Anything new on this issue? Spots from a cluster connected with Log4OM do not appear on SmartSDR panadapter
Andy K3UK
Andy K3UK
Currently, I am still using FRSTack to display Spots on SmartSDR. Wish it would be working directly from Log4OM without FRSTack.
Roland
Roland
I'm in difficult trying to figure out how to deal with Flex, mainly because i can't directly test it working or check the radio answer to my commands.
I've asked, some years ago, support from Flex in order to have a REMOTE device on their side with exposed ports so i can actively work with a real unit and test integration, but they asked a commercial agreement to sell the Flex plugin on behalf of me (providing me royalties and everything else) and i refused.
On the other side i was able to provide support for Expert Electronics SUNSDR in some weeks when they sent me a SunSDR2 QRP device to be used and tested in depth.
Unfortunate that the folks at Flex Radio were unwilling to accommodate this. Lots of us Flex users also use Log4OM.
You might try reaching out to the folks at https://www.remotehamradio.com/? They allow native remote connectivity to Flex radios. Perhaps they'd be willing to waive the annual cost given you'd be developing something worthwhile to their users, and also given the fact that you'd not be spending much time transmitting/etc.
Perhaps you now understand why I disposed of my Flex after 6 months of hoping for assistance so we could support it and why I upgraded to the SUNSDR 2 DX
