Cluster Color Delay
WB8ASI
Cluster Color Delay
Post by WB8ASI »
I'm running V1 and V2 next to each other watching the Cluster. Both are receiving spots at the same rate. V1 spots appear immediately with proper colors. V2 spots appear color correct EXCEPT those involving "worked same band" . The spots originally appear colored as "worked". Then there is a large delay (up to 1-2 minutes) before the "worked same band" color appears. Some even scroll off the screen before changing to proper color. If you click on the spot, it correctly reports "same band" right at the get go, but takes too long for color change. Anyone else having this trouble? Otherwise V2 is great. I'm just about ready to abandon V1. 73, Herb WB8ASI
NN7D
Re: Cluster Color Delay
Post by NN7D »
Herb,
Good catch. I can replicate that behavior. We missed that one, or it crept back in along the line.
Thanks for reporting.
Doug
W7DRM
