When clicking on Cluster spots changes my rig to filter 2 - IC-7300 ICOM
When I click on spots in the cluster my rig changes freq and such like it should although it changes the filter mode to FIL2 just wondering if anyone else knows how to fix, may not be a log4om issue but could be? Thanks
KD0SGX Minnesota, USA-MIKE
Re: When clicking on Cluster spots changes my rig to filter 2 - IC-7300 ICOM
Are you using OmniRig for CAT? If yes, that's the reason. Since I'm 100% FT8 these days I changed filter 2 to 3kHz.
There may be a 'better' way to 'fix' that, but I did not pursue it.
Vince
Vince
I just checked and mine does the same. I checked V1 and it does it too. I never noticed before because I already use FIL2 99% of the time. I assume a value in Omnirig’s IC-7300.ini file needs tweaking. Now it’s gonna bug me.KD0SGX wrote: 24 Jan 2020, 17:12 When I click on spots in the cluster my rig changes freq and such like it should although it changes the filter mode to FIL2 just wondering if anyone else knows how to fix, may not be a log4om issue but could be? Thanks
Steve, N4IAG
I have this issue as well.
On a IC-7610 and using Omnirig.
Didn't have it with Log4OM V1.
Any solutions?
73'
Mark
PC9DB
Any solutions?
73'
Mark
PC9DB
I am having same issue with a Flex Radio and another user has the issue with an Elecraft K3, both running Hamlib. Log4OM is sending commands to the radio to set the filter when changing modes. They should not be sending a filter command.
Dave wo2x
Dave wo2x
As I recall, its an Icom thing. Any mode change command to an Icom rig, at least on my IC-7600 - automatically selects Filter 2. At least that is the default behavior with the OmniRig IC-7600v2.ini file.
Check your IC-7300 Instruction Manual. In the Control Command section - Operating Mode. If the mode command first element is 06 - then Filter 2 is automatically selected. The Icom commands have a provision to also set the filter with the mode command, but I have a feeling (no time to wade back into that with OmniRig to verify) that OmniRig does not support the filter part of the Mode command.
My work around for that = set your desired, normal use filter as filter 2. This can be done in the Icom menu system. Then when the mode is set - you desired filter is set. You can still manually select filter 1 or 3 if desired or needed.
Doug
W7DRM
Doug
W7DRM
This is not an issue with LOG4OM.
I was able to modify the .ini file for OmniRig for my IC-7300 to force the filter to FIL1 on DIGITAL, SSB, USB, AM and FM modes. I kept the FIL to FIL2 for CW modes. You need to study the format of the .ini file by looking at it with NOTEPAD, or better yet, OmniRig's VERIFY.exe program. Once the format makes sense to you, you simply add an extra 01 at the end of the mode command strings, as well as the expected validate response. This 01 in this spot forces the FIL1. Example for USB:
Original Command Line
[pmSSB_U]
Command=FEFE94E0.2600.01.00.FD
ReplyLength=15
Validate=FEFE94E026000100FD.FEFEE094FBFD
Modified Command Line
[pmSSB_U]
Command=FEFE94E0.2600.01.00.01.FD
ReplyLength=16
Validate=FEFE94E02600010001FD.FEFEE094FBFD
This is for the IC-7300. Your rig may have a different code. This may or may not work with other rigs. I cannot speak to anything other than my experience with the 7300, which worked for me. If you decide to try it, save a copy of the original ini file in a safe place!
[pmSSB_U]
ReplyLength=15
[pmSSB_U]
ReplyLength=16
Yes, good work. Then OmniRig supports those Icom commands. Glad you waded in to it! Thanks.
Doug
W7DRM
Doug
W7DRM
