I installed V1.16.0 - tried to connect my favorite DX Cluster (it is a combined DX Cluster and Skimmer Server) - does not work -
Adress: arcluster.reversebeacon.net:7000
Maybe you need to integrate skimmer cluster in a next version. It is fun chasing with skimmer (e.g. local skimmer as SO2R installation)
Greetings and now uninstall it ...
Peter
Support of Skimmer Cluster
Greetings and CW for ever
Peter DF1LX
see u on the band
Peter DF1LX
see u on the band
Re: Support of Skimmer Cluster
Hi Peter,
checked your Cluster link and in the "Cluster Window" it works. The problem is that nothing is shown in the integrated cluster tab. Maybe Daniele can change something that clusters like this work.
- df5ww.PNG (39.51 KiB) Viewed 4148 times
If you run the AR user software or VE7CC software on your local computer and select reverse beacon you can then connect to the programs from Log4OM using either
127.0.0.1:7300
or
127.0.0.1:7000
Then the spots are displayed
127.0.0.1:7300
or
127.0.0.1:7000
