70cms as a band ??
G7BZD
70cms as a band ??
Post by G7BZD »
Hi.
Where do i find 70cms as a band when logging, as its missing from the drop down, goes as far as 2mtrs.
Now running V1.16.0.0
Many Thanks.
Phil
Re: 70cms as a band ??
Check that it is in your band list - Page 35 of the user guide
Check also if in the CAT & CLUSTER section of the config you can see the 70cm band enabled in cluster.
This will hide the band from some parts of the software too.
