WinKeyer variables
WinKeyer variables
Is there a list of variables for the macros on the winkeyer? I assume that is what they are called. <MY_QTH> as an example
One of the default Macros includes <MY_QTH> and that is City. State would be better but was not sure what that would be.
The default Message 5 has <NAME> which sends my name. I would have assumed that <Name> would be the station you are working and <MY_NAME> would be me.
Did not see anything in manual in the Winkeyer section.
Re: WinKeyer variables
No the items enclosed in <........> are extracted from your own information in the config station info tab, this is common practice with data mode and Winkeyer macros.
If I recall there is a list of these somewhere in the Winkeyer window, unfortunately I cannot check at this time as I am out and responding from my mobile phone
OK home now so here is the information which is in the winkeyer window - Macro info tab
<MY_CALL> or * My callsign
<CALL> or ! Counterpart callsign [from winkeyer form]
<STRX> RST received [from winkeyer form] with 9 replaced by N
<STRXF> RST received [from winkeyer form] as it's logged
<STTX> RST sent [from winkeyer form] with 9 replaced by N
<STTXF> RST sent [from winkeyer form] as it's logged
<NAME> My Name
<HIS_NAME> Counterpart name
<COUNTRY> My Country
<GRID> My GridSquare
<MY_IOTA> My IOTA
<MY_SOTA> My SOTA REF
<MY_OPCALL> Operator Call
<MY_QTH> My City
<MY_ANTENNA> My Antenna information
<MY_RIG> My RIG information
<CONT_TX> Contest SENT
<CONT_RX> Contest RECEIVED [from winkeyer form]
I did find a Tab under Winkey for Macro info.
There is no state in there so assume that is not available?
kd0zv wrote: 28 Jan 2020, 17:18 I did find a Tab under Winkey for Macro info.
No but if you provide a list of required macro entries we can add them
OK, not a big deal I can manually type it.
Thanks Terry
