The max records entry does not get remembered across restarts.
I like to keep mine at 25 to keep the refreshes quicker and used to do that on V1.
de Mike W9MDB
Max records memory
Re: Max records memory
Are you referring to the setting in the configuration or to changing the setting in the grid windows
I'm referring to the "Select x of z" max: entry on the F7 tab. And the same on the QSL Manager window.
That is not persistent. If you want your max to stay you need to change that in your config.w9mdb wrote: 29 Jan 2020, 22:28 I'm referring to the "Select x of z" max: entry on the F7 tab. And the same on the QSL Manager window.
- 2020-01-29_16-35-09.jpg (103.28 KiB) Viewed 3174 times
Ahhh..got it.
Thanks....
Thanks....
