Max records memory
Posted: 29 Jan 2020, 05:48
by w9mdb
The max records entry does not get remembered across restarts.
I like to keep mine at 25 to keep the refreshes quicker and used to do that on V1.
de Mike W9MDB
Re: Max records memory
Posted: 29 Jan 2020, 05:53
Are you referring to the setting in the configuration or to changing the setting in the grid windows
Posted: 29 Jan 2020, 22:28
by w9mdb
I'm referring to the "Select x of z" max: entry on the F7 tab. And the same on the QSL Manager window.
Posted: 29 Jan 2020, 22:35
by KD0ZV
w9mdb wrote: 29 Jan 2020, 22:28
That is not persistent. If you want your max to stay you need to change that in your config.
Posted: 29 Jan 2020, 22:39
by w9mdb
Ahhh..got it.
Thanks....
