Log4OM interface with WSJT-X not working
AH6TX
Post by AH6TX »
I have utilized both the ADIF function as by enabling the monitor and incorporating the correct adif file name and location.
I have also applied the UDP connection as indicated.
I don't know what else to do except to upload manually.
Please help.
AH6TX Howard
NN7D
Re: Log4OM interface with WSJT-X not working
Post by NN7D »
Hi Howard,
Could you please take screen shots of all your relevant settings in WSJTx and Log4OM V2 and post here. Also, are you using JTAlert? And the version # of Log4OM you are running - the latest public release is 2.2.0.0.
Please also read the FAQ on posting an issue.
Thanks,
Doug - W7DRM
AH6TX
Post by AH6TX »
I know this sounds ridiculous but I don't remember how to do a print screen. I have a key that says print screen and I have tried to push that with or without the shift and or the ctrl key. Please advise.
Howard
NN7D
Post by NN7D »
Howard,
If you are using Windows 10, you can use the Snipping tool to capture a portion of the screen, or a window, or dialog box, or any particular area of the screen. In the Windows search, enter Snipping tool to find the tool.
Doug - W7DRM
Or you can press CTRL/ALT/PRINT on the keyboard to make a screenshot of the active window of Log4OM or WSJT-X.
After use this command you can insert to Paint or another garaphics software.
