Hi
De-selecting the RTTY option in the User Preferences section does not stick when save and apply is completed.
LOG4OM-2 is stand alone (single User) and CAT interfacing is NOT enabled.
MS windows 10 Pro X64 Based PC
Intel Core i7 @ 2.67Mhz
Modes Selected Include AM, FM, SSB and CW only
1. In the "Configuration" section de-select the RTTY option then click "Save and Apply" (See "Configuration Screen" Screen Grab)
2. Go to the "QSO Capture Entry Window" the RTTY option still shows. (See "QSO Capture Screen" Screen Grab)
3. Moving back to "Configuration" section the RTTY option is again highlighted even though de-selected previously with "Save and Apply"
Hope this is enough information for you.
Cheers Adam
LOG4OM-2 - De-selecting the RTTY option does not stick
- Configuration Screen.JPG (91.34 KiB) Viewed 2716 times
- QSO Capture Screen.jpg (42.5 KiB) Viewed 2716 times
- Configuration Screen 2.JPG (85.85 KiB) Viewed 2716 times
Re: LOG4OM-2 - De-selecting the RTTY option does not stick
It's not a bug. You have RTTY set as default digital mode in CAT settings.
If Log4OM should use it, it will show it in the options even if you deselect it from preferred modes.
Hi Daniele
CAT control is not enabled...
My Alinco DX70TH does not have this feature and my IC-7300 has not arrived yet
Cheers Adam
Cheers Adam
It may not be enabled but if in the Program config that is set for RTTY the value will appear in the listVK4IM wrote: 03 Feb 2020, 03:10 Hi Daniele
Cheers Adam
Ah. I see...
Thank you gentlemen
Cheers Adam
Thank you gentlemen
Cheers Adam
