Worked before F10
Worked before F10
The worked before function is a nice tool. I have several callsigns and it would be nice to see if i worked a station with an other callsign. Is there any upgrade including this feature planned. Thank you OK8UN DJ9UN Lx1UN PY4ZUN
Re: Worked before F10
In future please post in the version 2 area, I have moved this topic
If you had all QSO'S in one log it would work as required just make certain that the owner, operator and station call signs are correct in the other logs before importing the ADIF
Hello, i real like Log4OM for old man. I have created different logbooks and imported my different logs such as LX1UN OK8UN and DJ9UN. the worked before is only working for the selected logbook. I was using in past Luxlog written by my friend LX1NO including this function. Maybe i didnt explain correctly in my previous note. However it was just question
But the answer to your question was to combine all three logs into one because Log4OM has such good search facilities you can still sort on each call for various things like QSL handling and awards etc.OK8UN wrote: 17 Feb 2020, 12:24 Hello, i real like Log4OM for old man. I have created different logbooks and imported my different logs such as LX1UN OK8UN and DJ9UN. the worked before is only working for the selected logbook. I was using in past Luxlog written by my friend LX1NO including this function. Maybe i didnt explain correctly in my previous note. However it was just question
However with a combined log you will see the required WB4 information
Hello thank you but to be honest i dont understand how to combine the logs.
I have 3 Logbooks
OK8UN
LX1UN
DJ9UN
Thank you
73 Alain
I have 3 Logbooks
OK8UN
LX1UN
DJ9UN
Thank you
73 Alain
OK8UN wrote: 20 Feb 2020, 11:38 Hello thank you but to be honest i dont understand how to combine the logs.
I have 3 Logbooks
OK8UN
LX1UN
DJ9UN
Thank you
73 Alain
Export an adif for two of the logs and then import them into the other log
thank zou that means i merge the logs
alain
alain
Yes but before you do check that the operator callsign is set in each of your 3 logs
for the 3 different calls.
More importantly the station call sign alsoDF5WW wrote: 20 Feb 2020, 15:53 Yes but before you do check that the operator callsign is set in each of your 3 logs
