I am trying to set up a friend's Alinco DX-77 to Log4OM, but I am failing and I don't know why..?!!
The only modification to the radio is a bhi DSP add-on, which shouldn't interfere with any of the ports etc.
We have bought an original Alinco ERW-4 cable to connect from the Alico's 'Remote Jack' to the COM1 port on the computer (running Windows 10) and selected Omnirig to use on Log4OM's CAT programming. These settings have been set using Omnirig with the radio's only baud rate of 9600. Omnirig of Log4OM is not seeing the connection.
So, I have tried further by connecting a reverse COM (inverted port thingy!) connection which leads to a USB plug. It finds this on Com Port 5... so I have tried COM5 using omnirig, again connected to the Remote jack, and Log4OM still doesn't read the radio frequencies...
Omnirig on both occasions were programmed into the second rig of the program and I have selected Rig 2.... Rig 1 for my Icom 756 Pro III works fine.
All the drivers are fine... so why am I having a problem with Log4OM reading the Alinco DX-77 using the ERW-4 cable connected from the remote jack to either COM1 or COM5....?
I'm going to try my linux mint laptop now....
Yours, very miffed and head bangingly clueless,
Thank you, best 73 and 88
Krystyna G5YL
