Edit Table Layout not responding to changes
WA2SQQ
Post by WA2SQQ »
1 While viewing cluster, right click and select Edit Table Layout
2 select Appearence
3 in Default Cell Style I selected a light green text, with intentions of selecting a black background.
4 Text color is now stuck on green. Attempting to change color is only temporary, reverts back to green once saved.
5 Reset Table Layout has no effect on selected colors.
Any suggestion on how to get back to black text on white background?
Obviously using v 2.3.0.0 under Win 10
Re: Edit Table Layout not responding to changes
Seems to work for me on 2.3
I assume you are editing both the rows to get the default and alternate and not messing with the selected row now.
I will say I was unable to make this look right because the callsign field was no longer visible for me expect on callsigns I had worked.
And the default was to different shades of grey for "back".
WA2SQQ wrote: 22 Feb 2020, 18:12
I would select "white" as the background and "black" as the foreground. That worked for me.
Now ... if you are also asking as to getting a reset back to the V2 "defaults" ... I've added that to our list of items to see about adding a 'reset' button that would also address the background and foreground colors of the the grid.
