Cluster Filter
pa2kw
Cluster Filter
Post by pa2kw »
Thanks for the new version and all the work done!
But.......
As a serious DX-er (DXCC- and slot- hunter), it is of great importance to be triggered by specific cluster spots.
Especially if you have worked most DXCC's and almost 3000 slots (DXCC related band-mode combination).
In Log4OM I already did a proposal to simplify the interface of cluster-filtering and getting more features at the same time.
(look at V1 Feature Suggestions, Topic : Cluster Filters, my message from 26 Dec 2015, 23:59)
Even the choice of words/text/description was discussed to get a better intuitive value.
It was judged as a good idea and put on the "To-Do" list (or whatever it is called).
Unfortunetely the filtering in V2 became less powerfull.
An extremely important filter function is either left out or I just didnt see it. In V1 it is called : "Mode needed on spot band".
PLeaseeeee have a look at this.
In the meantime I stay with the V1 version but prepared to discuss any improvement regarding cluster filtering any time.
73's, Evert PA2KW
BTW I do appreciate all the work done by Daniele and Terry!
Re: Cluster Filter
Provide a link to your previous request or explain in detail please.
pa2kw
Re: Cluster Filter
Post by pa2kw »
Thanks for the quick response!
The link to the extensive discussion is : https://forum.log4om.com/viewtopic.php?f=11&t=2006
You will find the proposal in page [2].
Additionally:
A missing important option in V2 that was available in V1 (or I didn't find it)
In V1 Main window : "Cluster" tab / "Highlights" Tab : missing option "Mode needed on spot band".
73's, Evert PA2KW
NN7D
Re: Cluster Filter
Post by NN7D »
Sorry, I am not following your request. In V2 you can easily see what modes you need on particular bands.
Example:
Doug - W7DRM
