Removing Skimmer spots from band map
K2MO
Post by K2MO »
All:
Is it possible to remove the CW skimmer spots from the band map? It becomes too cluttered in the default configuration so it might be better to have the ability to turn skimmer spots off and on.
Tony
Re: Removing Skimmer spots from band map
You need to turn them off at whatever cluster server you are using or use a different cluster
