porting a database and configuration on other PC
ik2egl
Post by ik2egl »
Hi
can you give me more info on how I can move/copy all needed log4om data on other PC on which lg4om has been already installed ?
what file I need to copy (and backup) ?
tnx
don
ik2egl
73 de Don IK2EGL
Re: porting a database and configuration on other PC
you can reach the configuration folder from HELP menu (last item in the help menu)
You need to copy:
config.xml
communicatorconfig.xml
all users modified files (files that ends with _user)
Next release will provide a backup of the config files in the backup folder
Please take note you should revise the whole configuration to check paths
ik2egl
Post by ik2egl »
Is it needet any other actio on the DATABASE ?
I use the SQLlite version
Don :geek:
73 de Don IK2EGL
ik2egl
Post by ik2egl »
I did a check on Config.xml and Communicatorconfig.xml, but they seem not to be in Ascii format neither editable.
Take note that I checked both them while log4om was running, but other XML files was editable (es clublog)
don ik2egl
73 de Don IK2EGL
You don't need to edit the files just copy them to a memory stick and then paste them to the same location on the other computer
Also just take a copy of your SQLite database to the other computer then all should work fine
config files are encrypted in BASE64 to provide a very very basic security to your configuration file.
You can find base64 online conversion websites on the net, if you're curious :)
I will probably unencrypt the file in a future version...
Obviously you must save config files and your log file. Your log file is backupped at every program close (if set, default yes) but you can save your database file and open it in another instance
ik2egl
Post by ik2egl »
I am trying a porting
Ok for the xml files, the location path is the same
But the path of the sql lite is different as I am moving from win64 to a win7 32 and the progam folder is named differently.
How can I make the sqllite visible on the second pc ?
Tnx
73 de Don IK2EGL
ik2egl wrote: How can I make the sqllite visible on the second pc ?
Tnx
Why not use Dropbox to store your logbook SQLite file then you can use it from either PC
See full instructions in the user guide
ik2egl
Post by ik2egl »
Hi Terry
You are right
But I did not setup the db file sqllite in dropbox os indipendent folder (my fault)
Perhaps I should have to setup another more standard nstallation from scratch and importing adif from previuos installation
73 de Don IK2EGL
Just copy the SQLite logbook file to the Dropbox folder - And then in Log4om go to file/open database and navigate to the SQLite file in the Dropbox folder - Job done :D
