is there a way to change the lotw sent status to a different setting, like changing the status from no to yes so when closing it wont find something under my old call, it hangs when exiting and cant sign log, been changing individual but thats time consuming!
Thanks!
Rick
global changes for lotw sent status
Re: global changes for lotw sent status
Rick,Ki4P wrote: 05 Mar 2020, 01:46 is there a way to change the lotw sent status to a different setting, like changing the status from no to yes so when closing it wont find something under my old call, it hangs when exiting and cant sign log, been changing individual but thats time consuming!
Thanks!
Rick
Yes, you can do "bulk editing". I did similar when changing many of my Q's from no to yes and requested to no or yes or some such.
Check out Page 68 under a label of "Bulk Editing" in the "current" User Guide. Be sure you download the "current" UG.
When you do this bulk editing ... try it first with 2-3 Q's to ensure you get the routine down pat and that you get the results you are seeking. Then expand you count of Q's for bulk editing.
