I am using V2.4.0.0. I am using Red for "Country Not Worked" and Green for "Country Worked". When I saw ZD7DC in the cluster it showed Red in the F8 Cluster and Green on the Cluster Screen obtained by clicking on the Globe icon. I have worked this call 4 times as shown by FG1 Statistics. Have I done something wrong in setting up the cluster colors?
Thanks in advance for your help
Dave Altwies, W8QXR
Cluster Colors
Re: Cluster Colors
Well remember you can configure both clusters separate.
As well as under view check to make sure you have options set the same on both for "Statistics view by"
- 1111.jpg (21.45 KiB) Viewed 2932 times
Re: Cluster Colors
Thank you, I think the problem is solved- I had one view set as "Worked" and the other set as "LOTW". They are now both set at "Worked".
Thanks again
Dave Altwies, W8QXR
Thanks again
Dave Altwies, W8QXR
Re: Cluster Colors
Glad to hear it.
