Moving log from DXBase 2007
ks4v
Post by ks4v »
I exported my log file via an ADIF file from DXBase 2007 with no problems. The field "LOTW received" has been populated, but all of the QSOs in LOG4OM are showing the "LOTW Sent" field equal to "No". Before I created the ADIF file from DXBase, I uploaded all of my QSOs to LOTW.
Is this field "LOTW sent" field showing "No" for all of my contacts going to be a problem going forward?
If it is going to be a problem, how can I change it?
Re: Moving log from DXBase 2007
Please check the user guide for bulk updates which you can handle in QSO manager. Not
a problem to use a search query for "LotW send status" <equals> "No". Now you can select
all contacts with this status and change them to "Yes" or "Y" or however V1 has handled
this. Meanwhile to long at V2 to check back, HI.
ks4v
Post by ks4v »
Would you be more specific with the SQL. The Lotw sent field is not in the drop down of fields to change, so I would have to use an SQL statement. That is what I need detailed help with. Thanks
Check the confirmations tab of the filter window
