It is not giving the exact match, JUST FYI
Invalid lookup
Invalid lookup
Mike Burton
xe2/n6kzb
xe2/n6kzb
Re: Invalid lookup
Mike,N6KZB wrote: 12 Mar 2020, 14:11 It is not giving the exact match, JUST FYI
It is working as designed. It does lookups a character at a time. How fast one is with keyboard entry can also affect this search/display.
Re: Invalid lookup
Not to mention its helpful in searching based on any part.
So if you are trying to look someone up based on their suffix you can. I have had to do that before because I could not remember anything but their call district and suffix.
Re: Invalid lookup
Thanks for the responses.
It is when you enter a call that you have started a QSO with, and then hit "worked before", then this:
And yes it does it in a search also. Just wanted to pass along to the software team. Minor issue in the scheme of things, since the LoTw is the greatest. Adios
Mike Burton
xe2/n6kzb
xe2/n6kzb
Re: Invalid lookup
Mike,N6KZB wrote: 14 Mar 2020, 14:54 Thanks for the responses.
The program is working as designed for the call-sign display. Now you seem to have a "typo" for that additional call ??
- QSOMngr-callsign-lookup.JPG (74.33 KiB) Viewed 5995 times
- MainUI-callsign-F10Tab.JPG (104.68 KiB) Viewed 5995 times
Re: Invalid lookup
No, not a typo, two different calls.
But thanks anyway.
Adios
But thanks anyway.
Adios
Mike Burton
xe2/n6kzb
xe2/n6kzb
Re: Invalid lookup
Any thoughts to a fix on this?
This is not the same call.
I can see if it was xxxxx/xx, a call with a suffix, such a /mm or /xe2.
Thanks....
Thanks....
Mike Burton
xe2/n6kzb
xe2/n6kzb
Re: Invalid lookup
Its not broke.
Its working as designed.
The only thing they could add is a checkbox for verbatim where it would show only that call.
Re: Invalid lookup
That would do it, give the user the ability to each EXACT match or not.
Frustrating to go to search and see other calls mixed in.
Good thought OM.
Good thought OM.
Mike Burton
xe2/n6kzb
xe2/n6kzb
