Invalid lookup
Posted: 12 Mar 2020, 14:11
by N6KZB
It is not giving the exact match, JUST FYI
- Annotation 2020-03-12 070809.jpg (50.73 KiB) Viewed 6072 times
Re: Invalid lookup
Posted: 12 Mar 2020, 15:12
by KI5IO
N6KZB wrote: 12 Mar 2020, 14:11
Mike,
It is working as designed. It does lookups a character at a time. How fast one is with keyboard entry can also affect this search/display.
Re: Invalid lookup
Posted: 12 Mar 2020, 16:27
by KD0ZV
Not to mention its helpful in searching based on any part.
So if you are trying to look someone up based on their suffix you can. I have had to do that before because I could not remember anything but their call district and suffix.
Re: Invalid lookup
Posted: 14 Mar 2020, 14:54
by N6KZB
Thanks for the responses.
It is when you enter a call that you have started a QSO with, and then hit "worked before", then this:
- Annotation 2020-03-14 075025.jpg (55 KiB) Viewed 6000 times
And yes it does it in a search also. Just wanted to pass along to the software team. Minor issue in the scheme of things, since the LoTw is the greatest. Adios
Re: Invalid lookup
Posted: 14 Mar 2020, 17:11
by KI5IO
N6KZB wrote: 14 Mar 2020, 14:54
Mike,
The program is working as designed for the call-sign display. Now you seem to have a "typo" for that additional call ??
Re: Invalid lookup
Posted: 15 Mar 2020, 12:51
by N6KZB
No, not a typo, two different calls.
But thanks anyway.
Adios
Re: Invalid lookup
Posted: 25 Mar 2020, 11:54
by N6KZB
Any thoughts to a fix on this?
This is not the same call.
I can see if it was xxxxx/xx, a call with a suffix, such a /mm or /xe2.
Thanks....
Re: Invalid lookup
Posted: 25 Mar 2020, 12:43
by KD0ZV
N6KZB wrote: 25 Mar 2020, 11:54
Its not broke.
Its working as designed.
The only thing they could add is a checkbox for verbatim where it would show only that call.
Re: Invalid lookup
Posted: 03 Apr 2020, 18:48
by N6KZB
That would do it, give the user the ability to each EXACT match or not.
Frustrating to go to search and see other calls mixed in.
Good thought OM.
