Missing azimuth entry in the log file
DK5OK
Post by DK5OK »
After saving the QSO, the azimuth data are not transferred to the log file. In version 1 they were available.
Re: Missing azimuth entry in the log file
Are those data from external software like WSJT-X via UDP messages ? If so Log4OM can´t do
anything if the Azimut is not provided. Having the same here with contacts in FT8 via UDP
from JTDX with or without JTalert.
By the way, checking massed updates to change this .... Stay tuned .... 8-) 8-)
No luck with a massed "Update Info" in QSO Manager. No changes for the AntAZ at the moment ... :cry:
DK5OK
Post by DK5OK »
Again. The azimuth data are all correctly available from the direction management. Only in the adif file after saving in the logbook are the Ant Az data not taken care of.
Added to Mantis list
DK5OK
Post by DK5OK »
What do you mean exactly?
Terry means that this problem is added to Mantis. At mantis we store all bugs and failures
that we have it in a list for bugchecking. So means too, we work on this problem.
DK5OK
Post by DK5OK »
Thank you for the info and that you take care of this problem. 73 Andi
