Secondary backup on network folder path
IW3SSA
Post by IW3SSA »
Good morning,
setting the secondary backup folder I cannot set a network folder because i cannot access to the network or links to network folders, but i can only see the list of the folders based on current pc.
I cannot also specify a path for backup in some manual way.
Can you help me please? Is it possibile to set a path for backup folder in some manual way?
Many thanks in advance and best regards.
G3ZSS
Re: Secondary backup on network folder path
Post by G3ZSS »
I just setup a secondary backup to my NAS without any problem using the pull down menu to select my Network, and then the NAS, and then the folder to put it in. The saved file is at;
\\MYNAS\Backups\LOG4OM\
So you should be able to do something similar?
73 Peter G3ZSS
IW3SSA
Post by IW3SSA »
Ok, many tnx, solved! I had internal network permits problems. Best regards and thanks for support.
