Azimuth is identified on the same line as the frequency at the top of the program. You have a field for it and the only thing it shows is "0". Is there something I can do to have it record it correctly?
Howard
AH6TX
gvm920@gmail.com
818-203-5337
WHY DOESN'T ANT AZMUTH RECORD ANYTHING BUT 0
Re: WHY DOESN'T ANT AZMUTH RECORD ANYTHING BUT 0
Howard,AH6TX wrote: 25 Mar 2020, 00:32 Azimuth is identified on the same line as the frequency at the top of the program. You have a field for it and the only thing it shows is "0". Is there something I can do to have it record it correctly?
Howard
AH6TX
gvm920@gmail.com
818-203-5337
Enter a callsign into the UI and watch what happens with the Azimuth. I'm guessing that might answer your question.
Yes I already indicated that it shows up on the same area the frequency is on. What I want to know is why the information doesn't show up in the database, especially since their is a field named Ant Azimuth. The only thing that shows is the number 0.
Yes it seems you found a bug I will add it to our Mantis list of jobs to doAH6TX wrote: 25 Mar 2020, 05:45 Yes I already indicated that it shows up on the same area the frequency is on. What I want to know is why the information doesn't show up in the database, especially since their is a field named Ant Azimuth. The only thing that shows is the number 0.
Thank you for spotting this
have checked that and you´re right. Also manually entered contacts are showing 0 now.
Still wondering so older contacts was logged by an older V2 Alpha and it was o.k. there.
