Hi there:
I've been working sats from different locations (different grids).
I don't know how can I create these different location to have "my_gridsquare" correctly
Any ideas?
Activation of different grids
Re: Activation of different grids
Easy, just add a different 'User configuration' for each grid in the Program Configuration menu.
Its easy to clone an existing config, make the new config 'Active' change the grid, amend your station call to /P if necessary then Save and apply
Thanks Tierry. I do it like you said, but I don't see any change at the first time..... I create a new configuration with another locator, I save it, but when I open again the program with that configuration, locator is still my main locator (not the new I created).G4POP wrote: 05 Apr 2020, 06:28 Easy, just add a different 'User configuration' for each grid in the Program Configuration menu.
But then, I closed/opened it again and now it's OK...
Many thanks
