I have a Yaesu FT-857D and a Kenwood TS-480HX. The Kenwood CAT-Connection is working without any problems with Log4OM2. But the connection to the Yaesu FT-857D is not working with Log4OM2 2.4.0.0. With Hamradio Deluxe for example the transceiver CAT-control of the Yaesu FT-857D is working fine.
I use Omnirig 1.19 and I already installed the newest ini-File for Omnirig but Log4OM2 can't connect to the Yaesu FT-857D. What can I do?
Yaesu FT-857D not working with Log4OM2 over Omnirig
Re: Yaesu FT-857D not working with Log4OM2 over Omnirig
Did you run Omnirig and Log4OM as administrator. This is needed to use the multithreading
function in Omnirig .....
Are all settings o.k. like COM, Baudrate ?
Yes, all settings are correct. I also started Omnirig and Log4OM2 2.4.0.0 as administrator. The only thing that happens when I start Log4OM2 is that the Yaesu FT-857D is switching from VFO A to VFO B and back again from time to time.
I am not sure if the reason is that I am using a Yaesu FT-857D and with Omnirig there is only the FT-857 available.
