I've setup Log4OM 2 (2.4.0.0) to use 2 different databases, 1 for Digital, the other for satellite. I'd like a different Recent QSO layout for each one.
Currently I can store virtually any other setting, for each, start using a specific shortcut and all is fine. When I try to set the Recent QSO layout, both databases change and look the same. I want to view Sat Mode & Sat Name for Satellite database but not for Digital.
Any ideas please why the individual layouts are not being saved?
Recent QSO Layouts
Re: Recent QSO Layouts
Rick,
At this time the layouts are not saved as part of a different configuration, if we get enough requests we might implement it perhaps.
What you could do instead of two configs with shortcuts is to install the portable version of Log4OM in addition to the installed version.
Use the installed version for one set up and the portable version for the other one this way they are totally independent setups using different folder sets
Thanks for the reply Terry.
I've just moved over and it's a pity because HRD v5 logbook had that function. Hopefully layouts can be saved one day.
Rick, VK6RK
OF77xw
OF77xw
