My cluster server is working (PRI) GB7MBC and so is the simulation mode. However using the Send Spot does not appear in the cluster.
Convinced its me not the software but cant find it. Help pls
Paul
Send Spot
Re: Send Spot
Hi Terry - Thanks for the response. Yes I am and have checked with Ian as well. GB7MBC is my primary cluster.
I did add GB7HTL in the connection tab but I never registered that one (dohh). The cluster has always populated like it was working and the simulation method also worked but no spotting possible. So, I have removed the above GB7HTL cluster from the list and the other thing I have done is in SDR console V3. The DX cluster was using the same gb7mbc.spoo.org:8000 could that have interefered being logged in twice? Anyway I changed that now to spider.ham-radio.ch:8000 in Console and it seems I can now spot OK...problem solved.
Sorry about that Log4OM now back on track
73 Paul
73 Paul
Re: Send Spot
If your going to use two instances of the same cluster, even on different computers, you need to add a unique SSID to each one
