Invalid ADIF format
OK1VK
Invalid ADIF format
Post by OK1VK »
Good day,
could you please help me with IMPORT ADIF format ???
I would like to import all my QSO from HRD log into LO4OM.
Unfortunately, LOG4OM reports an ADIF file error.
Log4OM v1 is the old Log4OM version - ADIF format imported without errors.
All 68 365 QSO loaded without a single error.
Log4OM since version 2.0.0.0. - Not connected to a valid database (Check settings)
Please send me an ADIF that will be fine.
Thanks in advance.
Pavel Slavicek OK1VK
[email protected]
Re: Invalid ADIF format
If they imported ok into V1 then export from V1 as an ADIF version 3 file, HRD is probably producing an absolute ADIF format
OK1VK
Post by OK1VK »
Nothing works.
ADIF 2, ADIF 3 - nothing
Why ok1vk.SQlite does not work in version 2.0.0. etc
I wanted to load the database, but it reports: Database seems not valid
[quote=OK1VK post_id=28562 time=1587191758 user_id=3310
[/quote]
Because as our user guide states Log4OM V2 uses a different structure
EMAIL me the LOG4OM V1 SQLite file or Log4OM V1 ADIF version 3 file and I will convert it for you - Use my email address as shown on QRZ
OK1VK
Post by OK1VK »
Thank you.
But this is not the solution. If I want to record any other ADIF from the Win-Test where I run Contest, it reports : Not connected to a valid database.
A log that cannot import ADIF files from contest logs is not usable.
OK1VK wrote: 18 Apr 2020, 12:55 Not connected to a valid database.
That message now tells me that you have not created a database in Log4om v2 when you installed it, you must have ignored/bypassed that requirement
I suggest that you follow the instructions in our user guides and YouTube tutorials and CREATE A NEW DATABASE then import the ADIF file
Please do not criticise our software without foundation, if you follow the instructions it will work for you the same as it does for our thousands of users
OK1VK
Post by OK1VK »
Good evening Terry,
Thank you very much for your help
You were right.
The mistake was on my side. I started wrong.
Very sorry.
The diary works perfectly and I am excited about all the features.
Thank you again for your help and advice.
I also apologize for my previous reports about the logo not working.
Pavel OK1VK
