Winkeyer Handshaking
K0VW
Post by K0VW »
Not having success with Winkeyer window and Main Log window sharing information. Version-1 did this well but not so with Version-2
1. Calls entered in Winkeyer window do not carry over to the main log window--Version 1 did this with tab key.
2. When in Contest Mode, Winkeyer window "worked before" alerts not confined to contest settings (date / times), instead they reference the entire main log (here too, the main log alerts work correctly, only alerting duplicate contacts made during the contest period).
Suggestion: Allow Winkeyer "direct type mode" to be locked when desired. Box unchecks itself routinely as log data is being managed.
Thanks for the great logging program, works wonderfully well. If you can help me out with these minor issues, I would be appreciative.
John (K0VW)
Re: Winkeyer Handshaking
K0VW wrote: 18 Apr 2020, 05:34 Not having success with Winkeyer window and Main Log window sharing information. Version-1 did this well but not so with Version-2
There is no advantage because the Winkeyer window now does the lookup whereas it did not in V1 which was why you had to tab to see the lookup in the main window
OK will add these to Mantis list
