Problem installing Log4Om. Station Country : (Empty list)
F4GJC
Post by F4GJC »
I want to migrate my portable version to the installable version to compare performance.
I installed the latest version of Log4Om.
I followed the configuration restore procedure.
I copied and then modified the backup file. (backup directory and database in the file to point to new directories)
Then following the procedure, I deleted the config.json file and copied the backup file and renamed to config.json.
When running the application, I have an error in the configuration. (Station Country)
I uninstalled Log4OM and deleted the folder C: \ Users \ USERS NAME \ AppData \ Roaming \ Log4OM2 \
Then I installed Log4OM again.
I did not play the restore procedure to go on a basic installation.
During configuration, it is impossible to choose Station Country. (Empty list)
thank you for your help
73 Christian
[https://forum.log4om.com/download/file. ... ew&id=3373
F4GJC
Re: Problem installing Log4Om. Station Country : (Empty list)
Post by F4GJC »
I use this work around.
I installed the installable version.
I copied the portable version files (config folder) to the C: \ Users \ USERS NAME \ AppData \ Roaming \ Log4OM2 \ folder
I modified the config.json file.
Log4OM works in installable version.
This version is a little faster than the portable.
The loading of the supercluster is always as long.
73 Christian
