Lotw upload problem v1
Re: Lotw upload problem v1
First you should try uploading an ADIF file using TQSL (Without Log4OM)
If that works you probably have a setting wrong in Log4om
If an upload by TQSL on its own fails then the issue is with TQSL, perhaps a certificate expired?
Always state when posting:
1. if it used to upload OK before or that this is your first attempt
2. Exactly what version of Log4OM you are using (Help/About)
3. If as in your case the error message is not in English you must translate it for us, we are not multi-lingual
4. Provide as much information as possible - We dont have a crystal ball
