Page 1 of 2
2.5.0.0 - Something goes wrong during Log4OM startup sequence
Posted: 22 Apr 2020, 15:16
by F4GJC
Hi
following the installation of the last version, a message is displayed during the execution of the program.
Something goes wrong during Log4OM startup sequence. Probably a missing file in configuration folder.
Check application log.
The message is displayed since the update. (2.4.0.0 to 2.5.0.0)
I created the file for support. (Generate support request)
What email address should I send the report to
Best regards
73 christian
Re: 2.5.0.0 - Something goes wrong during Log4OM startup sequence
Posted: 22 Apr 2020, 17:17
by F4GJC
Hi
For information:
Operating system: Windows 10 1909
DOTNET 4.8 (Version 4.7.2 is not available for the 1909!)
All internet communications seem to be not working. (QRZ, QRZCQ link while the passwords are correct.)
73 Christian
Posted: 22 Apr 2020, 17:42
by KD0ZV
I would download it again from the server, reboot and try it again.
Posted: 22 Apr 2020, 19:10
by F4GJC
I performed the following operation:
- uninstalling the application
- restart the computer
- download of version 2.5.0.0 from the log4Om site
- deleted C:\Users\Christian\AppData\Roaming\Log4OM2
- application installation (fresh installation)
- computer restart
-program execution
I still have the message that appears when loading the program.
for information, I downloaded and launch the portable version.
It works and does not display the message at startup.
Kind regards
73 Christian
Posted: 22 Apr 2020, 20:33
It would really help if you posted a screenshot of the message here, we don't have a clue what it says otherwise!
Posted: 23 Apr 2020, 06:04
by F4GJC
You will find attached to the message the screenshot of the error message .
I made a video but impossible to load it (2mo)
Have a good day.
73 Christian
- Log4OM-Err1.png (23.77 KiB) Viewed 6245 times
Posted: 23 Apr 2020, 11:23
by F4GJC
I read the RTFM documentation
Used to the portable version, I did not launch the application with administrator privileges.
If you are running as an administrator the application no longer displays the message.
Sorry.
Too bad for this limitation.
However, I installed the program outside the Files program directly at the root of C: \
I apply this method to all the amateur radio programs that I use without encountering problems.
Thanks for your help.
73 Christian.
For information.
When copying the contents of the portable version's config folder to the C: \ Users \ Christian \ AppData \ Roaming \ Log4OM2 folder, the message does not appear.
Posted: 23 Apr 2020, 11:56
Can you please send me the Log4OM logfile by email
Posted: 23 Apr 2020, 12:53
by F4GJC
Hi
Could you give me your email address or the address to use for you to send the logs.
73 Christian
Posted: 23 Apr 2020, 12:59
It is on QRZ but here it is
g4pop (at) arrl.net
