Manual Log Inputs
Manual Log Inputs
Given the present feature set, has anyone created the best work flow for manually inputting old contacts?
Re: Manual Log Inputs
Did you look at Lazy Log which we added a couple of releases back
Full instruction's in the user guide, download the latest guide
Yes I have. Unfortunately. we are talking about QSO's from the 19080's. Many of the ops have passed away and call signs have been reassigned. The lookup / update feature too often can't find the call or inputs the current info which isn't correct. It creates double work.
So just enter the QSO data
Can we add any fields to assist you like name etc?
If name, city, state and country were added, one could bypass the auto update and accept the manual input, as is. I’ve been told that there might be a 3rd party program that could also be used to create an ADIF file that can be imported.
Might be an interesting topic to get some user input on. I appreciate the offer to add fields, but the more input you get,the better it can be.
