I have 2 drives on my desktop pc , one is running under windows 7 pro ( cat works fine on log4om ) and the other which i am using runs under windows 7 enterprise , on the 7 enterprise i can not get cat to be connected through omnirig to log4om although i know the port is working as it works fine on wsjtx using this drive.
Can you help please..??
Thank you
Cat problem
Re: Cat problem
Have you checked out that Log4OM and Omnirig running with administrative privileges ?
Needed to use Omnirig with multiple softwares.
Re: Cat problem
Hi Thanks
for the reply
Tried with administration privileges
did not work
for the reply
did not work
