I recently added the prefix to the "Reference Description" in the DXCC award definition. You now have the same options to sort like in LoTW - either by prefix (click on the "Reference Description" column) or by country name (click on the "Country" column). Some people prefer sorting by prefix (like myself, because for me it's more logical if similar entities like, G, GD, GI, GJ, .. or KH0, KH1, KH2, K3, ... are in sequence), some by country name.
I used exactly the same prefixes that LoTW is using as well, so sorting by "Reference Description" should give you the same list like sorting by prefix in LoTW.
If you can't see the "Country" column, you have to scroll more to the right. Just as a reminder: all award reports a created dynamically, and you can't change the column order. Contrary to Log4OM v1, the DXCC award in v2 is like any other award and not hard coded anymore, which makes it much easier to make changes.
Claus, OE6CLD
DXCC Award
Moderator: OE6CLD
DXCC Award
Claus, OE6CLD/DJ0DX/EI7JZ
Re: DXCC Award
Hoping Lele moves that over
Thanks Claus
Thanks Claus
