Problems uploading qsos to Eqsl.cc
LU4FTA
Post by LU4FTA »
Hello, my problem is that when I paste the qsos made via satellite to EQSL.cc, the name of the satellite does not appear nor does the propagation "satellite", therefore they do not confirm the contacts because they are missing those fields. Because of that problem I must edit on the Eqsl.cc site and edit and correct these errors. I would like to know what the problem is. What am I missing in the configuration?
Thank you.
73 by Felipe LU4FTA.
Re: Problems uploading qsos to Eqsl.cc
Please try forum search before you open a new thread. Meanwhile we have 3 or 4 of them.
Please check this one: viewtopic.php?f=33&t=5428
LU4FTA
Post by LU4FTA »
Thank you very much Juergen for the answer and sorry if I did not see that this post was already in progress. One solution is to select and export in adif mode and then upload them. In this way, the PROP and Sat fields in Eqsl.cc look good.
73 de Felipe LU4FTA.
