Installation Question.?
G8LIY
Post by G8LIY »
I have downloaded the latest manual/guide, also watched the latest install YouTube.
I wish to run Log4OM2 and eventually use WSJTX
IF I understand correctly.?
I need to run the installers for both AS Admin, then Run the programs As Admin
Do I need OMNIRIG.?
Is this if you have multiple Radios.?, or does it just make it easier for Programs to interact.?
Many Thanks
David - G8LIY
Windows 10 Pro & LOG4OM - V2.29.0
NN7D
Re: Installation Question.?
Post by NN7D »
David,
If you want CAT to work with LOG4OM and/or WSJTX, then you will need to install and setup Omnirig within Log4OM. It's all in the User's Guide. In order for CAT via Omnirig to work with more than one program, then you will need to run each program as Administrator.
Doug
W7DRM
G8LIY
Post by G8LIY »
Hello Doug,
Many Thanks..
Sorry, I understand the "Running the Programs" "As Administrator"..
Do I need to run the Log4OM / WSJTX "installers" with right click, "Run As Administrator"
Regards - David
David,
Yes you do including Omnirig
G8LIY
Post by G8LIY »
Many thanks for the confirmation.
