Mysql database Help
M0XTG
Mysql database Help
Post by M0XTG »
Hi
I have an issue with Log4om2 creating the database on a server I have in a data centre
It does not seem to be a Log4om issue but an issue with the server not letting Log4om create the correct tables.
If i create the database using the server and then put the details in Log4om it connects to it all fine, but obviously log4om has not created the correct tables so does not function properly
If i had a MySQL database back up then i could restore that on the server then all would be fine.
SO the question is has anyone got a database backup they could let me have, or could create me a database backup please ?
Then i could restore it on the server, connect log4om to it and then change everything to suit.
Ideally a Mysql version 5.6
Many Thanks in advance
Chris
PS: I have log4om2 workign a treat using the sqllite, the reason i want a Mysql database is so that multiple users can connect to it for club events
NN7D
Re: Mysql database Help
Post by NN7D »
Chris,
Check out this thread for some good information on setting up a MySQL log. https://forum.log4om.com/viewtopic.php?f=33&t=5234
Doug
W7DRM
Or even download the latest user guide that has step by step instructions!
