SOTA CSV upload
sp9wpn
SOTA CSV upload
Post by sp9wpn »
I've generated CSV for SOTA upload, but SOTA website says:
Error on Line 1: Incorrect date format (dd/mm/yyyy)
Original CSV file is:
Code: Select all
V2,SP9WPN/P,SP/BZ-068,20-05-2020,0857,145.55MHz,FM,SP9AMH
V2,SP9WPN/P,SP/BZ-068,20-05-2020,0858,145.55MHz,FM,SQ9KCX
V2,SP9WPN/P,SP/BZ-068,20-05-2020,0859,145.55MHz,FM,SQ9KCN
V2,SP9WPN/P,SP/BZ-068,20-05-2020,0900,145.55MHz,FM,SQ9IAW
V2,SP9WPN/P,SP/BZ-068,20-05-2020,0902,145.55MHz,FM,SP9PJ
V2,SP9WPN/P,SP/BZ-068,20-05-2020,0921,145.55MHz,FM,SP9MOV
V2,SP9WPN/P,SP/BZ-068,20-05-2020,0923,145.55MHz,FM,SQ9PPT
V2,SP9WPN/P,SP/BZ-068,20-05-2020,0933,145.55MHz,FM,SQ9NKX
When I correct date to "20/05/2020", file passes ok.
Wojtek
Re: SOTA CSV upload
Hi Wojtek,
that's the original file not passed through excel or other application?
Because the code clearly states that the format should be dd/MM/yyyy so it's very strange and i need to try reproducing...
Let me know, thanks
Re: SOTA CSV upload
Did you perhaps open the csv file in a spreadsheet and resave it?
I just did a SOTA CSV export and this is the result
V2,G4POP,,25/04/2014,0919,5.3985MHz,SSB,G0EVV/P,G/LD-048
V2,G4POP,,02/05/2014,1009,5.4035MHz,SSB,G4ASA/P,G/TW-004
V2,G4POP,,05/05/2014,0920,5.4035MHz,SSB,M0IML/P,G/SE-015
V2,G4POP,,14/05/2014,1333,5.3985MHz,SSB,G8TMV/P,G/SE-013
V2,G4POP,,26/08/2014,0701,5.3985MHz,SSB,GM4MD/P,GM/CS-11
As you can see the date format is correct!
sp9wpn
Re: SOTA CSV upload
Post by sp9wpn »
I didn't touch the file. I suspect Log4OM uses Windows locale setting and this causes dates to look different in your and mine exports.
Wojtek
Re: SOTA CSV upload
sp9wpn wrote: 21 May 2020, 14:00 I didn't touch the file. I suspect Log4OM uses Windows locale setting and this causes dates to look different in your and mine exports.
Wojtek
Wojtek,
My apologies!
Apparently it either is not hard coded or the code is wrong because you are perfectly correct the date format changes in accordance with the format set in Windows.
I will see if anything can be done about this but for now please use the other windows time format
HB9BRJ
Re: SOTA CSV upload
Post by HB9BRJ »
This is part of my activation done 2 days ago, exported as CSV:
Code: Select all
V2,HB9BRJ/P,HB/AI-009,19.05.2020,1036,14.0585MHz,CW,DL1ASA
V2,HB9BRJ/P,HB/AI-009,19.05.2020,1037,14.0585MHz,CW,HB9AGH
V2,HB9BRJ/P,HB/AI-009,19.05.2020,1038,14.0585MHz,CW,EA2DT
V2,HB9BRJ/P,HB/AI-009,19.05.2020,1038,14.0585MHz,CW,HB9DDZ
V2,HB9BRJ/P,HB/AI-009,19.05.2020,1039,14.0585MHz,CW,K4DY
V2,HB9BRJ/P,HB/AI-009,19.05.2020,1040,14.0585MHz,CW,OZ7JZ
V2,HB9BRJ/P,HB/AI-009,19.05.2020,1040,14.0585MHz,CW,YO6CFB
The date format is not accepted by the SOTA database. Since SOTA started to accept ADIF uploads, I never used CSV again.
73, Markus HB9BRJ
Re: SOTA CSV upload
HB9BRJ wrote: 21 May 2020, 15:04 This is part of my activation done 2 days ago, exported as CSV:
Code: Select all
73, Markus HB9BRJ
Markus,
See my post above you need to change the windows date format to dd/mm/yyyy like 21/05/2020
HB9BRJ
Re: SOTA CSV upload
Post by HB9BRJ »
Thanks Gerry, fully understood. My message was:
Why tinker with date formats and CSV when ADIF works fine?
73, Markus HB9BRJ
