Log4OM and Fldigi on an ICOM-7300
Posted: 24 May 2020, 10:50
by PD0Y
So I am using Log4OM along with Omnirig. This works fine.
Then I start Fldigi and press CONNECT in Log4OM to connect to Fldigi.
This works like a charm, when tuning the VFO the frequencies change on both Log4OM and Fldigi.
But.. I can not get Fldigi to transmit. Whenever I want to CQ the radio just won't transmit.
In Fldigi I am not using RIGCAT or Hamlib (when I do I loose the connection to Log4OM)
Does any of you have any idea on how to fix this?
Re: Log4OM and Fldigi on an ICOM-7300
Posted: 24 May 2020, 11:31
Search this forum there are many posts explain that you need to use a VSP because FlDigi does not use Omnirig
Posted: 24 May 2020, 12:16
by PD0Y
I do have an USB cable running from the radio to the pc? Is that what you mean by VSP?
Posted: 24 May 2020, 12:30
PD0Y wrote: 24 May 2020, 12:16 I do have an USB cable running from the radio to the pc? Is that what you mean by VSP?
No a VSP is a Virtual Serial Port not a physical cable
Posted: 24 May 2020, 13:05
by PD0Y
Thank you. I will look further.
FYI I did a search on the website and this is what I've got
The following words in your search query were ignored because they are too common words: fldigi cat.
You must specify at least one word to search for. Each word must consist of at least 3 characters and must not contain more than 14 characters excluding wildcards.
That is why I considered asking the question.
Posted: 24 May 2020, 13:21
Did you read the user guide about setting up a VSP for FLDigi? if you missed it then try searching the user guide on FLDigi
Posted: 24 May 2020, 14:06
by PD0Y
I will thank you!
