cluster autostart
cluster autostart
I was trying to find any info ... Is a possible to set it as cluster will start automatically with the program?
Re: cluster autostart
Seb,M0QVE wrote: 26 May 2020, 20:54 I was trying to find any info ... Is a possible to set it as cluster will start automatically with the program?
This is all discussed in the "current " User Guide and Quick Start Guide. Terry has also covered Clusters in his YouTube Videos.
Assuming you have downloaded the MOST CURRENT User Guide do a search for "cluster" and start there. You can also observe the YouTube Videos one or two of which cover Clusters. I've provided link for you below.
To have Log4OM V2 "auto-start" a Cluster you have to go to: Settings / Program Configuration / Cluster and then tic the box labeled: Cluster Auto-Start
Of course you will have first had to set up a cluster to auto-start at: Connect / Telnet Cluster / Connection
Thus ... important to spend some time reviewing resources to do a clean set-up for your needs.
I know you will review and resolve to your needs.
Terry's YouTube Videos: https://www.youtube.com/channel/UC6Ppcj ... yavI-azOug
thank you thank you .... i am just blind... been looking and couldn't find it. 73!
