Hi there,
I noticed the propagation map doesn't update anymore when I tried today. When I click "Generate" there is no image rendered - seems there's something wrong with an external component (dvoa.dll?):
From the log:
020-06-02 04:55:09.5035 ERROR: [#=z$12c7lIQi5nCOp$t3w==][#=z$I92gVeIqYlYz$B46Fu15KQ=] : [EXCEPTION] Eine externe Komponente hat eine Ausnahme ausgelöst. System.Runtime.InteropServices.SEHException (0x80004005): Eine externe Komponente hat eine Ausnahme ausgelöst.
bei L4ONG.BL.VOACAP.VoacapEngine.#=zBFneZ8AXb_g7(String #=zYDmYMScD4RO6)
bei L4ONG.BL.VOACAP.VoacapEngine.#=z$12c7lIQi5nCOp$t3w==.#=z$I92gVeIqYlYz$B46Fu15KQ=()
could not get a more detailed info about the exception generated - it worked a few days ago.
73 Sascha
Vocap map not generated
Re: Vocap map not generated
Known issue I beleive that Voacap have now fixed this for next release
